dynatrace can put https response body
Web App is React.js sending data as HTTP Request Method: PATCH, customer needs HTTP response data displayed in Dynatrace.
were you able to get a resolution to this?
If this page and the backend service that is being hit are both monitored by Dynatrace, you should be able to dig into the User Action, view Top Requests at the bottom of the page, select the request/service, and look at the purepaths or some other breakdown to see more data, depending on what you are looking for.
