How do I view response body in Dynatrace
Thank you very much. Can I do it any other way?
There is no other way than using request attributes.
And why does it not suit you?
You can collect and view Response Body (and others, like Request Body, for instance) using Business Events:
You can even parse the Response Body to collect only the piece you need, and make it available as a custom metric dimension.
