Dynatrace flutter plugin issue
After implementing the monitoring of a Flutter application, following all the paths in the directory and the necessary configuration points informed in the flutter plugin.
After following the installation steps I’m getting the following below error :
../flutter/.pub-cache/hosted/pub.dartlang.org/dynatrace_flutter_plugin-2.237.0/lib/src/agent/http/http_client.dart:5:7:
Error: The non-abstract class ‘DynatraceHttpClient’ is missing implementations for these members:
- HttpClient.connectionFactory=
- HttpClient.keyLog=
Try to either
- provide an implementation,
- inherit an implementation from a superclass or mixin,
- mark the class as abstract, or
- provide a ‘noSuchMethod’ implementation.
class DynatraceHttpClient implements HttpClient {
org-dartlang-sdk:///third_party/dart/sdk/lib/_http/http.dart:1554:12: Context: ‘HttpClient.connectionFactory=’ is defined here.
void set connectionFactory(
org-dartlang-sdk:///third_party/dart/sdk/lib/_http/http.dart:1704:12: Context: ‘HttpClient.keyLog=’ is defined here.
void set keyLog(Function(String line)? callback);
lib/size_and_position/main_size_and_position.dart:56:20: Warning: Operand of null-aware operation ‘!’ has type ‘WidgetsBinding’ which excludes null.
- ‘WidgetsBinding’ is from ‘package:flutter/src/widgets/binding.dart’ (‘../flutter/packages/flutter/lib/src/widgets/binding.dart’).
WidgetsBinding.instance!.addPostFrameCallback(_afterLayout);
lib/app_clone/movies_concept/movies_concept_page.dart:46:20: Warning: Operand of null-aware operation ‘!’ has type ‘WidgetsBinding’ which excludes null.
WidgetsBinding.instance!.addPostFrameCallback((_) {
lib/app_clone/photo_concept/photo_concept_page.dart:88:20: Warning: Operand of null-aware operation ‘!’ has type ‘WidgetsBinding’ which excludes null.
lib/app_clone/shoes_store/shoes_store_page.dart:286:20: Warning: Operand of null-aware operation ‘!’ has type ‘WidgetsBinding’ which excludes null.
lib/app_clone/sports_store/sports_store_page.dart:225:20: Warning: Operand of null-aware operation ‘!’ has type ‘WidgetsBinding’ which excludes null.
../flutter/.pub-cache/git/circle_wheel_scroll-c22e01667a1bd952573d5cae087f6404ea69face/lib/circle_wheel_scroll_view.dart:696:24: Warning: Operand of null-aware operation ‘!’ has type ‘SchedulerBinding’ which excludes null.
- ‘SchedulerBinding’ is from ‘package:flutter/src/scheduler/binding.dart’ (‘../flutter/packages/flutter/lib/src/scheduler/binding.dart’).
SchedulerBinding.instance!.addPostFrameCallback((_) {
lib/animations/split_widget/split_diagonal_widget.dart:57:20: Warning: Operand of null-aware operation ‘!’ has type ‘WidgetsBinding’ which excludes null.
WidgetsBinding.instance!.addPostFrameCallback(_onLayoutDone);
lib/animations/split_widget/split_half_widget.dart:62:20: Warning: Operand of null-aware operation ‘!’ has type ‘WidgetsBinding’ which excludes null.
lib/menu_navigations/header_navigation/header_navigation.dart:56:20: Warning: Operand of null-aware operation ‘!’ has type ‘WidgetsBinding’ which excludes null.
Failed to package /Users/administrator/Downloads/flutter-samples-master.
Command PhaseScriptExecution failed with a nonzero exit code
Hi @saikishore , a new version of the Dynatrace Flutter plugin was published which contains a fix for this.
Can you please try it and let me know?
Hey @HannahM Thanks for solving this issue and I can be able to install the dynatrace flutter plugin now.
After following the steps in below link :
I’m unable to get the 3rd party calls, User Interactions & Gestures metrics in iOS.
I have tried all the steps in the documentation provided by the dynatrace flutter plugin.
Can you please provide any sample app with above scenarios you mentioned in the link and share with me ?
That’s great news. I see you’ve had an update on your question, so I’ll leave this thread for now.
