Flutter Plugin failed to initialize - unable to establish connection
Hi all,
I am testing Dynatrace Flutter Plugin with VS Code, I followed step by
  1. Create Flutter Project
  2. Run “flutter pub add dynatrace_flutter_plugin”
  3. download the configuration dynatrace.config.yaml. Store it in the root folder
  4. Include “import ‘package:dynatrace_flutter_plugin/dynatrace_flutter_plugin.dart’; void main() => Dynatrace().start(MyApp());” in to main.dart code
  5. Run dart run dynatrace_flutter_plugin in the root of your Flutter project
  6. Call flutter run and the application starts including Dynatrace OneAgent
Then I found error below
A Dart VM Service on Chrome is available at: http://127.0.0.1:57149/NFDnX6zcZuo=
[2024-12-02 12:48:38][ERROR][DYNATRACE]: Dynatrace Flutter Plugin failed to initialize. Error: PlatformException(channel-error, Unable to establish connection on
channel., null, null)
What I have missed step that need to run the plugin? Thank you.
Hi, Could you please share what version of Dynatrace Flutter Plugin are you using?
Hi, AndriiKh
I am using version 3.303.1
Okay, as a quick fix I would suggest to try to downgrade to version 3.299.1. We will investigate the issue on 3.303.1. What is platform causing the problem (Android/iOS/both)? And can you maybe share content of your dynatrace.config.yaml?
I am trying for Andriod. Here is my dynatrace.config.yaml
HI, @Lextech. Are you able to reproduce the issue with other version of dynatrace flutter plugin? And other question do you have any custom logic within your MainActivity, or GeneratedPluginRegistrant?
Hi @Lextech! Did you find the solution for this one? :slightly_smiling_face:
Hi, I solved this one after I selected correct Android phone emulator from VS code, not select any web browse or desktop
