No Buildscript block in build.gradle in Dynatrace Flutter exception
After following the described steps to set up a Flutter application with Dynatrace, an error occurred when executing the command “dart run dynatrace_flutter_plugin”. Here is the output:
Building package executable…
Built dynatrace_flutter_plugin:dynatrace_flutter_plugin.
[2024-04-05 16:32:40][INFO][DYNATRACE]: Dynatrace Flutter Plugin 3.287.1
[2024-04-05 16:32:40][INFO][DYNATRACE]: Trying to read configuration file: dynatrace.config.yaml
[2024-04-05 16:32:40][ERROR][DYNATRACE]: Exception: Could not find Buildscript block in build.gradle.
[2024-04-05 16:32:40][INFO][DYNATRACE]: Finished configuration of Flutter application ..
Flutter doctor output:
[✓] Flutter (Channel stable, 3.19.5, on macOS 14.4.1 23E224 darwin-arm64, locale en-PT)
[✓] Android toolchain - develop for Android devices (Android SDK version 34.0.0)
[✓] Xcode - develop for iOS and macOS (Xcode 15.2)
[✓] Chrome - develop for the web
[✓] Android Studio (version 2023.2)
[✓] IntelliJ IDEA Community Edition (version 2023.2.3)
[✓] VS Code (version 1.87.2)
[✓] Connected device (3 available)
[✓] Network resources
• No issues found!
To confirm, I created an application from scratch, and the error persists. On iOS, it works normally.
The format of the build gradle file has changed and is not compatible anymore to our automated script. I will update this post when this issue has been fixed.
This has been fixed in the latest update, Dynatrace flutter plugin version 3.287.2
