That’s correct, deep monitoring does not work for Microsoft SQL Server. Metrics are collected also in infrastructure mode and you can see distributed traces from your applications. If the host does not contain any other applications which can be deep monitored, it’s worth switching it to infrastructure mode.
Further to this. If you’re looking to see the DB statements that are being run on the SQL Server DB Process then you will need to deploy the Agent in Full Stack mode on the calling application. Dynatrace will then inject into the DB connection library and create a DB Service based in this data. Then under that Service you will see the SQL Statements showing up as requests.
