Monitoring of MS SQL disabled for internal configuration
Hi all,
Recently installed one agent on a host that turns out it has a MySQL running on it. In the process view the messages is shown:
"Cannot enable deep monitoring for this process**Injection to this process is disabled by internal configuration"**looking at the settings of the host this message appears
the toogle to monitor ms sql is disabled.
what is going on ?
Hi @MariettaAlmeida
Please check @Julius_Loman answer for the same issue. Give him a kudos. :wink:
Solved: Activation of Deep Monitoring was unsuccessful - Dynatrace Community
Best regards,
Mizső
thank you @Mizső will check then !!
regards!
HI ,
You will need to enter data in this fields for a MySQL database.
HI Radek,
I am looking for MSSQL not for MYsQL , please suggest for this ?
You have posted a screen shot of your MySQL configuration :slightly_smiling_face:
For MSSQL you need to enable the settings under Settings >> Monitoring >> Monitored technologies >> MS SQL
