Process group
HI Dynatrace team,
On host, the process group of MSSQL one showing, injection is disable due to internal configuration.
what is the reason and where can i enabled it, please check and let me know.
Hi @Kundesaibaba
Here you have solution: https://community.dynatrace.com/t5/Open-Q-A/Monitoring-of-MS-SQL-disabled-for-internal-configuration/m-p/203693
Radek
