Can Dynatrace integrate SAP to drill down to the code level?
Can you install OneAgent in SAP machines?
Best regards
Yes, we can install OneAgent
Hi @Candy,
it depends on which SAP system you need to monitor, ex. SAP Java-based systems such as SAP Business Objects, and Cloud Connector. should be possible to install OneAgent normally for full stack monitoring.
You can find more details here.
Best Regards,
Mohamed
A new approach to integrate SAP data with Dynatrace was launched at Perform 2024 leveraging PowerConnect: Dynatrace extends AI-powered observability for SAP together with PowerConnect
