SAP/ABAP/HANA monitoring: any best practices?
Who has some tips and tricks for monitoring SAP/ABAP/HANA with Dynatrace, there must be more than deploying the Dynatrace extension?
KR Henk
Hi henk_stobbe,
I think it will be around dashboards and custom events for the most important metrics after configuring the extensions for ABAP and HANA DB, also you can use the synthetic monitoring for ABAP systems.
Regarding SAP Java-based systems such as SAP Business Objects, and Cloud connector. should be possible to install OneAgent normally for full stack monitoring.
as for SAP Fiori, you can use agentless monitoring and Synthetic monitoring.
Regarding SAP SaaS-based solutions such as Ariba & Success factor, you can use the following methods only
- Synthetic checks for availability
- Real User Monitoring using the Chrome Browser Plugin
A new approach to integrate SAP data with Dynatrace was launched at Perform 2024 leveraging PowerConnect: Dynatrace extends AI-powered observability for SAP together with PowerConnect
Only drawback: it is not for Dynatrace Managed )-; !!
It actually is compatible for Dynatrace Managed. The PowerConnect extension was just published to the Dynatrace hub: SoftwareOne PowerConnect for SAP monitoring & observability | Dynatrace Hub
Perfect, this will make a very happy customer!:grinning_face:
