We have been using native-base in our react native project, but now since it is deprecated we are shifting to gluestack which uses nativewind for enabling tailwind css for styling.
In my babel.config we have using below plugin which is conflicting with nativewind/babel
as This Babel plugin transforms JSX into JavaScript function calls that React (or React Native) can understand. Automatic JSX runtime replace JSX with function calls from @dynatrace/react-native-plugin/jsx-runtime instead of the default react/jsx-runtime. The issue is NativeWind (Tailwind for React Native) also relies on JSX transformation to detect and apply className styles.
What can be the possible solution for this, how can we use both of them.Thank You.
