Do you have any news of the roadmap to Monitor React native Mobile App.As we are planning to go live by march 2020 ,so is there a chance to have this tool supporting by that time.
You can use the Dynatrace React Native Plugin to monitor your react native app. This plugin is currently in the Preview stage and not final.
When can we expect that its fully supporting .We are planning to go live by march 2020
Beginning of next year is our goal to make the plugin GA.
Yes. Rename the beaconURL to beaconUrl in the dynatrace.config. This bug is already fixed and will be published soon. Don’t forget to call npm run instrumentDynatrace afterwards.
Thanks it did worked !!
When we were using Dynatrace AppMon and enabled UEM in 2018 beginning, we were able to trace at the user level and get lot of information and track user issues effectively. However later that year Dynatrace Appmon was sunset and we starting using DtSaaS which didn’t allow these level of configurations.is there way to track user specfic information with the DTSaaS??
Hi is there any information with regard to track user specific information with the DTSaaS??
Can you describe in more detail what you mean by track user specific information. What kind of information?
import { Dynatrace } from '@dynatrace/react-native-plugin';<br>Dynatrace.identifyUser("MyUser");
This is possible with the React Native plugin. Take a look into this Dynatrace class and you will see that you are able to report values as well. Until GA I will try to extend the documentation to insert those cases.
Thank you so much .Waiting to see the document.Also looking to track the screen information how the session has been maintained like this user is in this screen and landed to next screen .Also need information that i can have crash video that what led to the crash ![]()
This Manual instrumentation code is working fine in JS file but its giving error in tsx file ..need help since we thought that TypeScript bridge is available within this plugin
Hi Ancy, thanks for the report. I looked at it and you are right. I will try to fix this with the next release.
Thanks much.Any time line for this??mean for next release ![]()
We are currently working on changes for RN 0.62. But this change is already on the list. I sadly can’t give you an exact date (probably up to 2-4 weeks).
Thank you for the information. No problem.
Hello, I’m experiencing issues with the React Native app on iOS when I run the “npm run instrumentDynatrace” command.
