Monitor React native Mobile App
my environment:
react-native-cli: 2.0.1
react-native: 0.59.10
dynatrace / react-native-plugin: 0.186.0
Android: 10
iOS: 13.3
gradle-5.4.1
Hello Gustavo,
I think you should create a support ticket. This section explains which information should be provided.
Thank you Thomas, I will create.
This happens when the library is not correctly linked. Try to unlink and link again.
We did it and it didn’t work, the error continues.
Okay then you need to open a support ticket and we have a closer look. I can only tell you that DynatraceNative.PLATFORM_ANDROID is defined in the native part of the plugin. This error can only occur when this native part is not found. Check your XCode project and see if you can find the DynatraceRNBridge.m. (Maybe the project is not added correctly by React Native)
Thank you.is this fix available now?
Yes. The fix is already available. I again checked code piece above and it works without any troubles.
Oh Ok Thanks.
Need a help we were not able to see the web request logs in dtsaas console ,can you help to enable the network performance and enable crash logs what is the client configuration needs to be done
This can’t be explained or solved in short words here. You need to open a support ticket and we will take care.
Sure …Thank you..!!
Can you help with the process for same??
Hi, i’m working with dynatrace on react app and i have a question, when open the app, i saw this error. Do you know for this? i tried run npm start --reset-cache, or remove cache babel with watchman command but it’s still not work :disappointed_face:
Enviroments:
ā€œreact-nativeā€: ā€œ0.64.0ā€
ā€œ@dynatrace/react-native-pluginā€: ā€œ^2.257.1ā€
Android: 11
gradle: 6.9
==== babel.config.js =====
