I have a plan to install Dynatrace Managed in linux, in the documentation default setting is like this :
- Installation path (binaries):
/opt/dynatrace-managed
- Dynatrace Server data files:
/var/opt/dynatrace-managed
Can I customize this installation directory ? lets say I want to point the Dynatrace Server data files to /opt directory
I’ll just add an example to make this answer 100% complete:
To configure data storages:
./dynatrace-managed-installer.sh --datastore-dir /opt/dynatrace-managed-data --rpl-datastore-dir /opt/dynatrace-managed-data/session-replay --cas-datastore-dir /opt/dynatrace-managed-data/cassandra --els-datastore-dir /opt/dynatrace-managed-data/elasticsearch --svr-datastore-dir /opt-dynatrace-managed-data/transactions
Or just run the installer and specify new paths in the interactive mode.
hmaran
4
It appears that the link provided in Antonio’s answer is no longer functional. Here’s the updated link:
