Hello
We installed dynatrace managed and has pointed path new installation is not “/opt” after the installation is done, there dynatrace directory in the opt. Can we move the dynatrace directory out of the "/opt "?
Thank you.
You have to use the --agent-dir argument for the node installer to deploy oneagent to different directory on cluster node.
I think the /opt/dynatrace/oneagent symlink has to stay there.
About /opt/dtrun I’m not sure, looks as a temporary directory created at installation/upgrade time. I think this will be recreated during cluster upgrade anyway.
Since this does not take almost any space in /opt - is there a reason for deleting this stuff?
Hi Julius
Because the /opt space is limited, we are afraid of making it uncomfortable if we remove it. Will there be any impact on Dynatrace managed?
This /opt/dtrun has 16kB on one of our systems. I don’t think this size does matter on any host.
