[Dynatrace Managed] New Mission Control endpoints and IPs
Hey Community!
As being community members you can be the first who know. We’ve updated our network requirements for the outbound communication from a Dynatrace Managed cluster to Dynatrace Mission Control.
There are 2 new IPs:
46.137.81.205, 52.48.91.146
And three new domains :
mcsvc-us.dynatrace.com, mcsvc-eu.dynatrace.com, mcsvc-ap.dynatrace.com.
That will be used to transmit health checks, license updates, software updates etc. We recommend to update your firewalls to the updated list - this will allow to better utilize Mission Control endpoints. What I would like you to take from this announcement and change:
1. Update your firewall
2. Plan new deployments, new cluster nodes in network that allow to connect to Mission Control to all IPs/endpoints.
3. Don’t be afraid if you see new domains - they are still safe :wink:
4. We will start gathering the information which IPs are opened on your side and contact with you to adjust them within next year.
5. Your connection will still continue to work properly over the IPs you’ve used till now - we are fully backward compatible!
See updated Outbound Communication to Dynatrace Mission Control.
Thanks!
Ok, thanks for the info, please don’t forget to update the PoC pptx documents with this info.
I mean the Dynatrace POC Planning template (480eae38-44d2-411a-b64d-b35b36a51bb1Dynatrace POC Planning template (Sept 2019).pptx) In the Partner Portal -->Library section
Thank you, very much appreciate the heads up
Hello @Radoslaw_Szulgo
Thank you for sharing this updated information.
Babar
