Where is Mission Control deployed?
Hi All,
I have little query about the Mission Control, There are 5 domain for mission control. All 5 hosted in U.S. region? All are physical servers or the Dynatrace Cloud?
Thanks in advance.
Hi @gauresh_shinde ,
All 4 (four) endpoints are front-end servers located around the world - the US, Europe, and Asia/Pacific. Each region server individually serves updates from its local repository. However, the backend server and the database that stores all gathered data from clusters, are based in the US. We utilize the AWS cloud for this.
Hi @Radoslaw_Szulgo,
Thanks for the information.
Hi @Radoslaw_Szulgo ,
Can you please tell me which country for Asia/Pacific region?
Singapore
Do we have some documents for this?
Yes - we list all IP addresses here:
and then you can check IP’s geolocation. For example:
Can we Accept-list cluster nodes to mission control on only 52.221.165.63 IP & mcsvc-ap.dynatrace.com Domain
We can configure Your license to prioritize Singapore (mc-ap) endpoints over the others. So cluster will use those two IPs. Only if they are not available cluster fail back to others. Is that OK?
