Hi
We want to enable remote permissions to Managed clusters when Dynatrace support is needed and disable them normally.
However, it is not possible to access and change the settings with an account that has cluster administrator privileges. Does anyone know the procedure for changing the settings?
Mission control public ips are allowed in clients firewall network using a proxy server or public facing active gate. Mission control is accessible to Dynatarce P1 team for supporting customer’s issue to seek the needful access to DT instance cluster. Refer below threads.
Just make sure you are logged into Cluster management console with Administrator/ Owner rights to change this settings.
How does Mission Control pro-active support work? | Dynatrace Docs
Solved: Re: Communication between Mission Control and Dynatrace Managed is one-way or two-way? - Dynatrace Community
Hi techean-san.
I accessed as a user with administrator permissions, but I cannot change the remote access settings.
I understand the role of mission control. However, I want to enable the remote access setting only when support is needed.
Hi @Shirai , this setting is blocked for your license. Please reach out to our Dynatrace ONE team and request to enable this option in the license for you. This would enable you to adjust the setting whenever you want.
Hi @Radoslaw_Szulgo
I understand your answer.
The Managed cluster running in our company was unable to change the remote access permission settings. However, we were confused by the fact that some customers could change this setting and others could not. Can your managed clusters participating in this thread change the remote access permission settings? I’m interested.
As I mentioned this is our license setting to allow changing this or not. I believe now the default is to allow change it for new licenses. However, old clusters might still need to ask for the change.
Just confirmed with D1 team, you can raise access request through support desk.
