Missing option "Read-only access to all" in CMC for Remote access
In trying to restrict Remote Access to Dynatrace to a Managed cluster but I cannot find the permission “Read-only access to all” in the CMC settings:
Based on the documentation, that opcion should be available: Configure Cluster remote access — Dynatrace Managed Docs
Am I missing something?
Thank you.
DamiánG
Maybe it’s a license issue like in this thread:
https://community.dynatrace.com/t5/Dynatrace-Managed-Q-A/Dynatrace-Managed-remote-access-settings-cannot-be-changed/m-p/187298#M1979
Best Regards
Pawel
Thank you Pawel.
You’re right. I’ve contacted Dynatrace support via live chat and they enabled the option remotely.
DamiánG
Check the issue solved:
I’m glad that helped :slightly_smiling_face:
