Hi Team,
I’ve been experimenting with Dynatrace MCP recently and it’s pretty awesome when it explains things related to problems and the root cause. One thing I found quite annoying is that the URL it would return in the response.
If I ask it explain problem P-26045551 it explains every detail, root cause and everything perfectly but at the end it says if you want to see this problem in Dynatrace UI, go to this URL: https://{environmentid}.apps.dynatrace.com/ui/apps/dynatrace.davis.problems/problem/P-26045551?from=now%28%29-2h&to=now%28%29 and then it says problem not found/failed to load problem which is pretty annoying.
I guess it’s probably this part causing the issue from=now%28%29-2h&to=now%28%29
But it’s strange why these details can’t be picked up from the problem’s start and end time and added dynamically while forming the URL.
Any workarounds ?
@Maheedhar_T
