We are having issues instrumenting Dynatrace on our python application which runs on AWC ecs fargate
App container OS: bullseye OS
Dynatrace injection method: runtime injection
we are using below options:
flavor=default&include=all
We did try to add DT_LOGLEVELCON=INFO in our app container too.
results:
1. we couldn’t see any anything in the app container logs
2. one agent container logs doesn’t have any error pulling one agent & unzipping it
3. does DT support python app on the ecs fargate container?
4. what are the next steps to get this moving ?
thanks
We had quite the issues with fargate just based off how fargate is designed. Were you able to get it sorted out @vinnu_arige_moe ?
Hi @vinnu_arige_moe!
Python monitoring is currently not supported on AWS Fargate but is on the roadmap.
Best regards,
Alex
we haven’t got any luck with DT as its not supported but we went OTEL route to resolve our Python on ECS Fargate requirement
I dont see AWS fargate Python specifically on your roadmap? Can you point me to right one?
@patrick_thurner can you please provide more details regarding Python support for AWS Fargate.
@_Alexander_ Do we have a confirmation if Python based application monitoring is now supported out of the box with OneAgent deployment on Amazon ECS Fargate without the need for sdk instrumentation?
@jellypuno can you please provide feedback
Hi @Mohitnama , This should be supported now.
