ECS Fargate Monitoring with Infra only mode
Does Dynatrace oneagent support ECS Fargate monitoring with infra only mode?
Tarun
No. As fargate is serverless, there is operating system under your control where OneAgent can be even deployed.
You can use OneAgent build-time or run-time injection, see Monitor AWS Fargate — Dynatrace Docs , but this is the full stack mode.
You can also use Cloudwatch integration to get metrics or logs.
