Dynatrace OneAgent installer for MacOS
How to install oneagent on MacOs?
Please provide the solution with proper execution steps with detail explanation.
and why MacOs is not there in Oneagent installer OS list?
MacOS is not a supported operating system for OneAgent (also not for any other component). For OneAgent supported os see documentation.
Then any solution on this, how can I use Dynatrace on MacOs?
You cannot install OneAgent there, but you can use Dynatrace web UI.
Best regards
