I have tried to set up Dynatrace for my dummy app, as I am trying to explore opportunities to use this platform in a real project. My Concern is, after following the steps given in the setup docs, I am still getting an error: Dynatrace OneAgent (iOS) auto-startup was not successful, error code = -3
Can someone please help me out with why I am facing the same? Thanks
This is too little information - we would need the agent log, best with DTXLogLevel set to ALL.
To not publish your log here publicly and expose your settings I suggest to create a support ticket at https://support.dynatrace.com/
And just to make sure, you did add the configuration displayed in the instrumentation wizard to the Apps Info.plist?
Hi patrick, Yes I have added configuration in info.plist, I am suspecting that there is permission required from user for this, which I am not handling as of now as I am testing this on simulator.
Below I am attaching log as it is just dummy project on which I am testing.
2022-10-07 16:32:55.725765+0530 weatherApp[10879:219272]
INFO
AgentSession [Dynatrace.m:179-259-1] Turning ON all diagnostic categories
2022-10-07 16:32:55.727954+0530 weatherApp[10879:219272]
INFO
AgentSession [Dynatrace.m:220-259-1] Auto-starting Dynatrace OneAgent (iOS) version 8.251.1.1005 built on 2022-09-21 03:48:03 +0000
2022-10-07 16:32:55.728217+0530 weatherApp[10879:219272]
INFO
AgentSession [DTXAgentBootController.m:83-259-1] ### Dynatrace OneAgent (iOS) 8.251.1.1005 built on 2022-09-21 03:48:03 +0000 ###
2022-10-07 16:32:55.728543+0530 weatherApp[10879:219272] +[NSString dtx_sanitizeString:error:]: unrecognized selector sent to class <some hexadecimal, not relevant>
**2022-10-07 16:32:55.729387+0530 weatherApp[10879:219272]
SEVERE
AgentSession [DTXAgentBootController.m:258-259-1] agent startup -failed ex: NSInvalidArgumentException , desc: +[NSString dtx_sanitizeString:error:]: unrecognized selector sent to class 0x10208bd58 ,
Removing Stacktrace here.**
2022-10-07 16:32:55.729738+0530 weatherApp[10879:219272]
SEVERE
AgentSession [DTXAgentBootConfig.m:31-259-1] Dynatrace OneAgent (iOS) auto-startup was not successful, error code = -3
Thanks, this output is helpful - it looks like -ObjC is missing from the Other Linker Flags in your build settings - so I guess the agent framework was added manually and not via Cocoapods or Swift Package Manager OR you are you using the static framework. See Set up OneAgent for your iOS apps in RUM Classic — Dynatrace Docs on how to add this linker flag.
And yes, also the Privacy setup needs to be done to get more data.
Thank you for such quick response, really appreciate it!
