FYI. We have faced an issue at many custormers with Dynatrace Operator. We have received ActiveGate token expiring error at containerized AGs. (Fullstack - Managed)
Operator log:
{“error”:“getting reference \“XXXXXXXXXXXXXX/linux/activegate:latest\”: Get \“https://XXXXXXXXXXXXX/v2 /\”: tls: failed to verify certificate: x509: certificate signed by unknown authority”,“level”:“error”,“logger”:“dynakube”,“msg”:“error reconciling DynaKube”,“name”:“dynakube”,“namespace”:“dynatrace”,“stacktrace”:"Get \“https://XXXXXXXXXXXXXXXXX/v2 /\”: tls: failed to verify certificate: x509: certificate signed by unknown authority
4 hours ago Dynatrace Operator version 0.14.2 released on GITHUB. I hope it will be reached soon via RHEL channel and there will be an official documenatation about it.
I also had a similar problem on several environments late last week. The log entry was the same and new certificates had to be generated on the client environment side.
However, I do not know if this is a 1 to 1 problem.
The situation on my client’s environment was such that I had to, as I mentioned, generate new certificates (because the client uses its own) and re-generate access tokens. This was happening on a Managed environment.
{“error”:"getting reference \“dynatracexxxxxxxxx.hu/linux/activegate:latest\”: Get \"https://dynatracexxxxxxxxxx.hu/v2/\ “: tls: failed to verify certificate: x509: certificate signed by unknown authority”
Change the dynkube yaml ( skipCertCheck change from true to false and add trustedCAs entry with the above created configmap value) and reload it in the dynatrace project:
