Rancher Activegate Token Expiry
Deployment status displaying a warning
Rancher Activegate
“There are activegate tokens that will expire in less than a month”
Since this is a containerized Activegate, where can I disable token rotation and what is the procedure to make the change?
We do not want the tokens to expire
Hi @alejandro_herna,
We had a same issue under openshift wit dynakube operator 0.14.0 and 014.1.
Solved: Dynatrace operator 0.14.0 or 0.14.1 issue - Dynatrace Community
Finally we set the skipcheckcert to fals in the custome resourse yaml as a workaround and imported the dt managed server cert into openshift. Based on the documnetation in dynakube operator 0.15.0 the issue has been solved. Do you use dynakube operator?
Dynakube operator 0.15.0 release notes last sentence:
Dynatrace Operator release notes version 0.15.0 - Dynatrace Docs
  • The skipCertCheck parameter is now correctly propagated to the image library.
I hope it helps.
Best regards,
Mizső
