How to change an OpenShift ActiveGate expired token
Hi everyone,
ActiveGate, which is automatically installed on Openshift, receives an expired token warning.
I created a new token. But how do I add this token on openshift activegate.
If I operate on the pod, this token will be deleted when the pod drops.
Is there a general setting?
Thanks.
Hello @Osiris5654 in this case you need to update your Dynatrace Operator token. The ActiveGate token is rotated by Dynatrace Operator every 30 days. When an authentication token is rotated, the affected ActiveGate is automatically deleted and redeployed.
