we have updated our Expo project to SDK 55, which is now using Gradle 9.0.0 instead of 8.14.3 for Android builds.
With that our android builds are failing with the following errors:
FAILURE: Build failed with an exception.
* Where:
Script ‘<redacted>/node_modules/@dynatrace/react-native-plugin/files/plugin-runtime.gradle’ line: 7
* What went wrong:
Execution failed for task ‘:app:mergeReleaseAssets’.
> Could not find method exec() for arguments [plugin_runtime_35t1c0y1jua3q16b3tb5ka2j4$_run_closure1$_closure2$_closure3$_closure4@7e601b89] on task ‘:app:mergeReleaseAssets’ of type com.android.build.gradle.tasks.MergeSourceSetFolders.
We are using version 2.333.1, which is depending on Gradle 9 compatible Android Gradle Plugin version 8.333.1.1106.
Anything we are missing to get our builds running with Expo 55 / Gradle 9?
