Dynatrace SaaS and Splunk
Has anybody successfully, integrate Dynatrace SaaS with Splunk. And how?
I am aware that AppMon has and matured intergration.
Hi Jeppe,
I wanted to comment on this to see if you were still looking for a solution. If so, please reply. I have not implemented a solution myself, but we began working on an integration with splunk and decided to go another route. I do think I can give you some valuable info, though. If you are interested, please reply here.
We are also looking into this, bit cannot find any info at all?
Hi Hayden,
Please help with steps or video link how to integrate with SplunK.
This reference might be helpful - https://www.dynatrace.com/technologies/integration/splunk
Hi All,
Please check the Dynatrace App for Splunk and Dynatrace Add-on for Splunk.
