We have got a requirement to integrate Splunk with Dynatrace OneAgent (SaaS).
Could you please guide us with the integration procedure, any different methods to integrate, and any dependencies? If possible please provide any screenshots if available.
The easiest way to do this is to set up the Dynatrace App for Splunk and the Dynatrace Add-on for Splunk.
The Add-on is responsible for executing the rest API calls and collecting the data from Dynatrace
The App provides a collection of dashboards and saved searches
The Dynatrace Add-on for Splunk contains four distinct input types.
Timeseries Metrics: a pre-defined collection of Dynatrace metrics that feed the App’s dashboards as well as ITSI’s APM Module (Note: by default the Dynatrace App for Splunk assumes all data is written to a “dynatrace” index)
Entity: Selectively choose which entities to collect data for (Applications, Services, Hosts, Processes &/or Process Groups)
Problem: Details about problems that Dynatrace detects within a given environment
Timeseries Single Metric: Any single timeseries metric that Dynatrace tracks
We are currently using the plugin, but I’m really more interested in exporting user session data. I’ve been told to point DT to Splunk’s endpoint. Still trying to determine what that is.
@William S.
Have you guys been able to figure this out? Like you, I’m trying to push user session data from DT to Splunk but I’m trying to figure out how to set up an endpoint in Splunk. I was able to do this with ElasticSearch easily, but I’m having difficulties with Splunk.
