Splunk Observability platform integration with Dynatrace
Looking to understand the integration patterns for receiving data (metrics, logs) from Splunk and incorporating into Dynatrace dashboards.
Hi @dsteinbrick ,  there is no direct integration, and it’s going to be messy either way.
Realistically this needs to be done at the collection point rather than export - especially for the big 3 metrics, logs and traces.
For this I’d suggest option 2 - it will just make life so much easier.
Last time I checked Splunk only had minimal capabilities of streaming data as an export to 3rd parties.   Maybe there is something on Splunk base that could do this.  There is a dynatrace add on, that can send metrics, problems .. to splunk *(does not cover logs or traces)
If you’re after events only, then this is easy → standard search query with alert & use option 1 or the events api as an endpoint for the alert to send to. You could possibly extend this to certain scheduled searches.
For the big 3
1. use the OpenPipeline — Dynatrace Docs to ingest data and export from Splunk (you’ll need to figure that part out)
2. Adding a Dynatrace exporter to the Splunk OTEL collector (I’m assuming you are using this since you mentioned Splunk observability).  you can dual stream to both Dynatrace and Splunk.  benefit here is that you get raw data and it’s going to be able to be used directly in dynatrace.
e.g
apiVersion: v1
kind: ConfigMap
metadata:
  namespace: observability
  labels:
    app: otel-collector
data:
  otel-collector-config.yaml: |
    receivers:
      otlphttp:
        endpoint: 0.0.0.0:4318
    exporters:
      splunk_hec:
        token: "<your-splunk-hec-token>"
        endpoint: "https://<your-splunk-hec-endpoint>"
        source: "otel"
        sourcetype: "_json"
        index: "main"
        disable_compression: false
        max_connections: 20
        timeout: 10s
      dynatrace:
        api_token: "<your-dynatrace-api-token>"
        endpoint: "https://<your-dynatrace-endpoint>/api/v2/otlp"
        tls:
          insecure: false
    processors:
      batch:
        timeout: 5s
        send_batch_size: 512
    service:
      pipelines:
        traces:
          receivers: [otlphttp]
          processors: [batch]
          exporters: [splunk_hec, dynatrace]
        metrics:
          processors: [batch]
        logs:
          processors: [batch]
If your not using the splunk otel collector, you could also possibly try and fudge a heavy forwarder to send to the open pipeline by using the HEC configuration.
be the guineapig 😀
Enjoy
