Splunk or Kibana integration to Dynatrace
Hi all
is posible to bring data from Splunk / Kibana to dynatrace ?
some step by step wizard that can be shared also, would be helpful
thanks in advance
You can extend Dynatrace in these ways.
Best regards
Hi @AntonPineiro in summary, there is not an out-of-the-box extension already so i must build it from zero?
Or using some Dynatrace API to ingest data, it depends which information you want to integrate.
Best regards
To complete, perhaps OpenPipeline’s (not yet released) will be able to address this use case natively:
