Dynatrace SAAS document correction
HI Guys,
mentioning this for a minor correction in document for Dynatrace SAAS
documentation under below link has wrong file name
https://www.dynatrace.com/support/help/deploy-dyna…
correct file name : config.properties (/var/lib/dynatrace/gateway/config/)
While in document it is given as custom.properties.
Kindly make the correction.
THanks
HImanshu Mor
Hi Himanshu,
I don’t think that’s incorrect. custom.properties can be replaced by the default settings at every upgrade but custom.properties should be retained at an ActiveGate upgrade.
best regards
Franz
Do not edit config.properties. Make all changes needed in custom.properties (and create this file if one does not exist).
HI @Dave M.,
My custom.properties only has below text. Please suggest if i should copy all from config.properties and paste it in custom.properties?
cat custom.properties output below
[synthetic]
synthetic_browser_monitors_enabled = false
synthetic_enabled = false
Hi Himanshu,
you don’t need to copy config.properties into custom.properties. config.properties is the default and you only need to copy these lines to custom.properties where you want to deviate from the default.
best regards
Franz
Perfect ! Thanks @Franz S. , this is what i explicitly wanted to know!
