Dynatrace SaaS - Lambda logs
Hi
Is there any way to get access to Lambda logs via Dynatrace SaaS?
At the moment, the basic metrics available, but for example in case of errors we wanted to know what is happening in logs and why errors are happening with lambda functions.
thanks.
br,
Farid.
This is on the roadmap. If logs will be stored in S3 bucket, we will use Log Analytic premium to download them onto local storage and analyze online.
Any update on this?
@tarjei_utnes @farid_sharipov you can use the new Log Monitoring and get Lambda logs from CloudWatch Log groups in Dynatrace with connection to your monitored Lambda functions. You can start here: Log monitoring with AWS log forwarder — Dynatrace Docs
