Dynatrace is able to monitoring AWS services and enable traces on AWS Lambda functions.
But, do we have a way to trigger execution lambda function from Dynatrace perspective?
Best regards
Best regards
Hey Anton,
Since Lambdas can be invoked via a web request, depending on how you have it setup you should be able to invoke it using a synthetic or problem alert.
Thank you! :smiling_face_with_sunglasses:
Hey Anton,
If you need to sign requests with AWS sig v4 theres this tutorial by HannahM on how to do that too.
HTTP Monitors: How to sign a request for AWS Signature Version 4 - Dynatrace Community
Thank you! I will have a look!
Best regards
