Dynatrace & ServiceNow multi-tenant support
With the Dynatrace to ServiceNow integration is there support for a multi-tenant ServiceNow implementation? Can we configure Dynatrace to send event & incident data to more than one ServiceNow instance?
Yes that’s possible. Simply set up more than one ServiceNow integration within Dynatrace and configure your ServiceNow instances to access the Dynatrace API.
Best,
Wolfgang
