Integrate same dynatrace tenant to 2 serviceNow instances
Hi Team,
I need to integrate two serviceNow instances for the same Dynatrace tenant (environment).
Regards
If you plan to use incident integration, you only need 2 different problem notifications using the same Alerting profile
Both instances will be notified.
