Dynatrace Synthetic Scripting capabilities
Hello everyone.
Need to automatically apply current date to a date field each time my web transaction is re-played. Shown below is the code from dynatrace synthetic script.
I added the following "var date = (today.getMonth()+1)+‘-’+today.getDate()+‘-’+today.getFullYear() to the TextValue field.
Each time web transaction is replayed, the date field is not displaying the current date. I only see the text from the code.
Any help would be greatly appreciated.
I am new to json coding but I am eager to learn!
Thank You!
“type”: “keystrokes”,
“target”: {
“locators”: [{
“type”: “css”,
“value”: “input[name=\“dos\”]”
“type”: “dom”,
“value”: “document.forms[\“Form1\”][9]”
“type”: “css”,
“value”: “.form-control:eq(2)”
“type”: “css”,
“value”: “#Form1 div:nth-child(5) div:nth-child(2) div:nth-child(2) div:nth-child(3) div:nth-child(2) input”
“type”: “css”,
“value”: “#Form1 div.panel div.panel-body div.form-horizontal div.form-group div.col-sm-8 input.form-control:eq(0)”
“masked”: false,
“simulateBlurEvent”: true,
“description”: “keystrokes on \“dos\””,
“textValue”: “var date = (today.getMonth()+1)+‘-’+today.getDate()+‘-’+today.getFullYear()”
“type”: “javascript”,
“wait”: {
“waitFor”: “time”,
“milliseconds”: 2000
“description”: “Current_date”,
“javaScript”: “var rightnow = new Date();\nvar date = \”\" + (rightnow.getMonth()+1) + \“/\” + rightnow.getDate() + \“/\” + rightnow.getFullYear();\napi.setValue(‘date’, date);"
Hi Richard,
do you still need help with this? If yes, is the web application you are scripting against public? You should be able to achieve this with a JavaScript event. See https://www.dynatrace.com/support/help/how-to-use-dynatrace/synthetic-monitoring/browser-monitors/browser-clickpath-events/#javascript-
Kind regards,
Philipp
