How to add today's date using variable dynamically in the keystroke event in browser monitoring?
how to add today’s date using variable dynamically in the keystroke event in browser monitoring ?
You need to create your own JavaScript clickpath event for calculate that date, and input in correct field.
You have JavaScript examples in that link.
Best regards
Hi Anton
Thanks for your reply.
Do you have the link of this script.
As am don’t see the examples in the above link.
They are in same page in you scroll down.
Best regards
no I don’t see it
Please share the screenshot
It means, you do not have a specific example for your use case. You need to development your own JavasScript code to:
  1. Create a today’s date in correct format.
  2. Fill field with that value.
Best regards
