Dynatrace V2 API - How do I call a custom device?
I have an Oracle custom device that I would like to pull Oracle database statistics for?
mydatabaseservername.example.com:1521/mydatabasename
entitySelector=type(HOST),tag(Custom~device:mydatabaseservername:1521/mydatabasename)
metricSelector=builtin:tech.oracleDb.cd.cpu.idle
I can see it in the UI and see this values. I am banging my head trying to figure out how to get that stat via the V2 API.
What am I doing wrong?
Help!!
Lou
Hello @louis_gallo
It seems at the moment we can perform only the following to the custom device:
  • Report custom device metrics via REST API.
  • Creates or updates a custom device.
  • Lists all the available logs on the specified custom device.
  • Gets the filtered content of the specified log.
Babar
I am able to do this and it gets all the custom devices.
entitySelector=type(CUSTOM_DEVICE)
metricSelector=builtin:tech.oracleDb.cd.cpu.idle:names:merge(dt.entity.custom_device)
This actually works but returns the data for all custom devices.
Can I create a tag for a custom device to help break it down further?
Lou
Yes you can also Tag custom devices, either in the GUI directly on the Entity under Technologies or via Settings → Tags → Manually applied Tags. Another option would be to use automated tagging rules or the tagging API.
