Hi!!
Is it possible to ingest a custom metric (via API v2) to a customDevice?
I see in the documentation the example to a HOST-id, but not to CustomDevice-id
Br
Jose A
Hi!!
Br
Jose A
Hi!
You have a couple of options here:
- You can use that same API v2 ingest endpoint only using a dt.entity.custom_device as the dimension to filter by. That way you can then create a chart in the data explorer that you can filter by custom device.
- There’s also a specific endpoint, using a different format, for the reporting of metrics to custom devices: Report custom device metric via Dynatrace API — Dynatrace Docs
Álvaro
Hi @JAR let me know if @alvaro_sanchez suggestion helped you as per your ask.
Were you able to resolve the metric appearing with APIv2?
