Hi ,
Like to know is the any way to monitor ECS and EKS certificate monitoring , any POC if yes please give the steps.
Any customizations that i need to do in Dynatrace agent.
Regards
Amar
Hi ,
Regards
Amar
Hi Amar,
Have you tried to install SSL Certificate Monitor extension? You can deploy the extension on an ActiveGate or on any host with the OneAgent installed, which is your case. When deployed on an OneAgent, the extension will attempt certificate auto-discovery. The extension uses data collected by the OneAgent to help identify certificates on the host.
Hope it helps.
Elena
