Hello:
This is in the context of installing the Elasticsearch extension…
Error message:
Failed to assign monitoring configuration to ActiveGate.
Reason: The monitoring configuration requires ActiveGate version 1.265.0 or later that supports data source python (runtime version min: 3.9.0) and belongs to group “elasticclustermonitoring”
The attached screenshot has the Properties and Modules enabled for the Environment Activegate.
EAG version - 1.297.7.20240820-171627
Unfortunately, none of the Reasons mentioned in the Error message is true for the EAG.
What could be causing the extension to fail to install?.
Thanks!
