Enable Azure Entities and Metrics at Scale for Comprehensive Monitoring
Hello.
We are looking for a method (UI preferably) to enable massively Azure resource types (“Manage Services” button) and additional metrics that are not ingested by default.
It takes a lot of time to do it manually, you have to click every resource type and every metric.
Anyone with same pain journey ?
BR
Hey @Theodore_x86 ,
I just wanted to check in and see if you still need help with this. If so, I’d be happy to look into it for you! :blush:
Hello @IzabelaRokita
Yes I think it is a valid request. Especially when you handle a lot of connection points with AZURE.
BR
You should be able to do it through the API, right?
