Hello!
Does anyone know if I can graph the following information from a host process on a notebook?
Deep monitoring
Hey @tsagredo ,
I just wanted to check in and see if you still need help with this. If so, I’d be happy to look into it for you! :blush:
You ever figure this out? I’d like to do the same. We’ve detected a problem with our Red Hat hosts where Full Stack monitoring is turned on for the hosts, but processes aren’t deep monitored and, when you go to manually enable deep monitoring, you see a message saying “No OneAgent Module is detected for this process”. Running diagnostics on the host reveals thousands of file permission issues with the OneAgent files. I’d like a report to see how widespread this problem is, but haven’t figured out a way yet because I can’t find any fields that tell whether Deep Monitoring is active for a process in Grail…
@36Krazyfists this information is not currently not in Grail and the I&O app also uses the API. The status of injection can be accessed by API or JavaScript SDK (code tile). See a more complex example here.
Ahh, that’s a bummer. Hopefully this info will be added to Grail soon as that would be super useful for building easy reports and dashboards to highlight deep monitoring issues like this.
This is a real annoyance as we move more into DQL; hopefully the team ensures it is part of Gen3 and sdv2.
Requests for this feature have been pending for two years, and with the remove of Classic enitty API, we will no longer have access to this status, as seen on the new Gen 3 UI views?
