My organization has web application built on Microsoft PowerApps. I am looking to see if anybody has had success with instrumenting PowerApps with manual JavaScript injection for Microsoft Powerapps.
Moses.
Moses.
We are just starting this for some AWS Services that serve up our webfront. You should be able to manually define the application name and Dynatrace will then give you the Json payload which the app teams need to then include in their application header.
TO read more about it check this out: Set up agentless monitoring in RUM Classic — Dynatrace Docs
Hi @moses_chacko , Did you have any success with this please? I am looking for some guidance on similar topic
Hello, did you implement RUM on Power App Canvas app in the end?
