RUM & Power BI Report Server
is it planned to support Real User Monitoring auto-injection for “Power BI Report Server” of Microsoft?
Hello @Arnaud_GERMAIN
Real User Monitoring auto-injection is done by OneAgent and is supported for the following technologies/servers.
Babar
Hi Arnaud,
Have you tried to install the oneAgent on that server? My guess is that if the underlying technology is supported by Dynatrace, for example IIS, it should work automatically.
If there is another non-supported technology, you could always monitor the user experience by using the Set up agentless monitoring in RUM Classic — Dynatrace Docs
Hello Babar,
I know this link… This is why I ask this question.
Hello @rodrigo_alvare1, yes the oneagent is installed on that server but RUM is not activated.
We cannot use RUM browser extension.
The link was shared just to know the supported technologies OOB. Did you try the agentless Real User Monitoring?
Babar
So I guess something is conflicting with the automatic injection at the IIS level. Do you know if you can add any custom html/js in the screens provided to your clients? If that is the case you can add the reference to the js agent
