I am using Terraform to enable all GCP extensions 2.0 in my tenant.
Considering the following blocks:
# Get available extension 2.0 items from hub
data "dynatrace_hub_items" "extension2_0" {
type = "EXTENSION2"
# Add each google extension
resource "dynatrace_hub_extension_active_version" "google_extensions" {
for_each = { for item in data.dynatrace_hub_items.extension2_0.items : item.item_id => item["artifact_id"] if startswith(item.item_id, "google-") }
name = each.value
version = "1.0.5"
The resource dynatrace_hub_extension_active_version requires a specific version.
Is there a way to get the latest version for each extension & pass it ton the resource block?
I’m also interested in whether all GCP extensions are released with a common release number? E.g. will all extensions release 1.0.6 at the same time (if indeed that version was to be released)?
