This post is an answer to the MCP Server Challenge :robot:
# Short Abstract
It should be possible to use Agents to understand customer Terraform configuration. Based on this Agent should be able to use dtctl to check what extensions there are for used technologies (both installed and available in hub).
Agent should then be able to suggest resources that can be used to monitor those technologies (OneAgent or ActiveGate groups) and create monitoring configurations for them
# Current status
During implementation ![]()
