OneAgent extension - request for configuration elements
Hello all,
We are using a custom OneAgent extension that displays certain fields for its own configuration.
We have thousands of hosts having this extension used and configured.
(On premise Dynatrace)
I am wondering how to get all those configuration elements by API ? To get a result like field name:field value for each host in a json.
Thx and regards.
Pierre
Hi @PierreLamonzie
you can get each host extension data using extension API (example below)
Then You can do a script to iterate on step 5 and trigger step 6 for each result from step5
1 - Generate token with - read config
2 - go to configuration API and authorize
3 - Find “/extension” and list all avaiable extension:
  /api/config/v1/extensions?pageSize=200
4 - copy id of you extension for example:
  custom.python.cert_plugin
5 - use id as parameter for “extensions/{id}/instances”
  /api/config/v1/extensions/custom.python.cert_plugin/instances?pageSize=200
  you will get list of custom configured instances:
     “configurationsList”: [
      “id”: “HOST-4544E85D1B018C76”
    “totalResults”: 1
6 - now go to “extensions/{id}/instances/{configurationId}”
  fill id and configurationID:
  /api/config/v1/extensions/custom.python.cert_plugin/instances/HOST-4544E85D1B018C76’
  in response you will get configuration of plugin in specific host:
  “extensionId”: “custom.python.cert_plugin”,
  “enabled”: true,
  “useGlobal”: false,
  “properties”: {
    “CertList”: “”,
    “ExpDays”: “366”,
    “Split”: “;”,
    “LogFileLocation”: “C:\\ProgramData\\dynatrace\\oneagent\\log\\plugin\\”,
    “DebugLevel”: “INFO”
  “hostId”: “HOST-4544E85D1B018C76”
Hope it helps
Bests
Michal
Thanks a lot Michal, it works perfectly !
